-   -   2.7 Alusol jug reline possible? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1100053-2-7-alusol-jug-reline-possible.html)
SunburntLobster 08-15-2021 06:58 AM
Out of interest is it possible to reline an Alusol jug with a new nikasil (?) liner rather than bin them or is it cheaper to buy new jugs and pistons?
eastbay 08-15-2021 07:23 AM
Lots of shops do it, try EBS racing in Reno, they have an exchange program.
Walt Fricke 08-15-2021 10:13 PM
It isn't really a liner (not a sleeve) - they spray the hot metal on the surface, then machine it back to spec. It is very effective, and a really good way to use worn Ausils.
Walt Fricke 08-15-2021 10:17 PM
Though, come to think of it, some shops will bore the cylinder out, heat it, and insert an iron liner, which is then machined to the right ID. You end up with a later day version of the Birals Porsche used on their earlier S models. The assertion is that this gives a very good wear surface as well as more dimensional stability.
SBell 08-15-2021 10:37 PM
I've seen it mentioned by an engine builder on here that Alusil cylinders redone in Nickasil are actually better than factory Nickasil cylinders because the alloy KS used has more silicon in it so they are more thermally stable than the Mahle cylinders.
Sent from my SM-G991U using Tapatalk
Rosco_NZ 08-16-2021 06:31 PM
Yes, more silicon in Alusils. Nikasil is a chemical treatment, not sprayed on. It can flake off and be redone but takes best to aluminium which has not previously been Nikasil treated, therefore Alusils really good candidates for Nikasil process. They do have fewer fins 9 vs 11?) but I don’t expect this would create overheating issues, providing you’re running an external cooler.
Walt Fricke 08-16-2021 08:27 PM
I got that wrong - nikasil is a plating process - electrochemical might be the way to describe it?
Alusil is finished by etching, which removes some aluminum and leaves the silicon particles exposed.
Henry Schmidt 08-16-2021 08:49 PM
Absolutely correct.
stownsen914 08-18-2021 04:30 PM
Regarding the iron liners in 911 cylinders and dimensional stability,, I’ve heard some say that for higher boost turbos, the iron liners are preferable as aluminum/nikasil cylinders can go oval. Not sure if it’s true, I’ve wondered.
Rosco_NZ 08-22-2021 02:01 AM
In the same way that high HP applications (power adders) use steel liners inserted into the block, same goes for steel liners into Porsche cylinders. Not sure at what point this becomes necessary but certainly make stronger cylinders and improved head sealing.
Speedy Squirrel 08-25-2021 08:05 AM
Turbo’s are hot, they run hot, and the air going into them is hot. One has to trade off structural strength with thermal conductivity. At around 220 for Aluminum vs 45 for Iron thermal conductivity, aluminum wins. Turbo cylinders usually fail from detonation. Cooler more important than stronger. For the two valve engine there is no amount of boost that will change that trade off.
Other engines have water cooling, in which case that trade off flips. Plenty of cooling.
Flat6pac 08-25-2021 05:59 PM
As long as you’re sending the cylinders to plate, you might consider 92mm to 2.8 with cr of 9.5 to 10.0
Bruce
SunburntLobster 08-25-2021 10:45 PM
Many thanks for your contribution, I managed to get smoking deal on unused set of Mahle P&C's.
