Crankcase mating surface shiny or dull?
I am rebuilding my 2.7 mag motor.
The old casing sealant has been removed but the mating surface is a dull grey however I can scrub it back to shiny. Is this necessary for a good seal? I don't want to damage it if I can leave as is. Cheers! |
Ingenieur
The answer is - no. As new they came with a zinc dichromate coating, which is a sort of dull gray. Aggressive cleaning will remove it and the surface will then appear shinier. It is not uncommon to see both on a case mating surface, patches of gray, and also shinier areas.
Great thanks. I shall make sure they are cleaned and degreased and not go too crazy trying to get them shiny.
It's a 914 ...
Do clean thoroughly of course, but I've never heard anyone say shiny or dull is preferable for a proper seal.
Ensure the surfaces are flat....
As you are rebuilding a Mag case motor, I trust all appropriate machine work had been done? Align bore check/machining, case mating surfaces trued, case savers/timeserts installed, maybe dowel pins, spigot bores trued etc?? If not, don't worry too much about which surface finish is appropriate for the mating surfaces.... Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
