-   -   Wiring for a 3.2 project (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1102079-wiring-3-2-project.html)
dpetteng 09-11-2021 01:04 PM
So I have a 1971 VW camper van that has been completely rebuilt and built around a 3.2 1985 carrera engine which has been rebuilt alongside a 915 transmission.
This has been fitted with PMO carbs as I want something that will be more like a vintage engine.
So an earlier post on here helped me figure out that ignition will work with a 2.7 distributor (with 3.2 drive gear) and a 3 pin CDI unit.
The bit I don't know and can't figure out is the rest of the wiring. What cables need to go to the CDI unit? is it simply a positive from the ignition switch?
Also, I have the original alternator and loom but unsure how to wire this up.
Looked at a few 85 wiring diagrams but none clear enough to work out how to backdate this to distributor and CDI unit wiring instead of the original 85 ECU setup. Anyone?
snbush67 09-11-2021 05:26 PM
Originally Posted by HarryD (Post 11364154)
This is the Pin out for the 3 pin connector:
http://forums.pelicanparts.com/uploa...1623880508.JPG
Check out this thread.
http://forums.pelicanparts.com/porsche-911-technical-forum/1095897-76-911-cdi-wiring.html
dpetteng 09-13-2021 08:38 AM
Originally Posted by snbush67 (Post 11455153)
Link doesn't work?
snbush67 09-13-2021 05:30 PM
