Porsche 911 oil line
Hello,
Can someone please give me the part number for this oil? Its for a 1983 Porsche 911SC. Thank you in advance. |
This will do it
91110774312 Bruce Be sure you can remove the outer hose to the oil tank at the thermostat because that nut has to come loose before you can get to the nut to change the hose in the picture. If it won’t loosen, you’ll need to diagonally cut the nut to get it off, then hit it with a hammer and chisel. You might need to do that to the hose you want to change. Oil tank to thermostat hose is 91110773013 Bruce Last edited by Flat6pac; 09-11-2021 at 08:07 PM.. |
Thanks Bruce, will start juicing the lines then before trying to undo them.
