-   -   Need advice - Leak-down great, Compression test not so much (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1102537-need-advice-leak-down-great-compression-test-not-so-much.html)
hcoles 10-25-2021 04:56 AM
^^^ good setup. As far I can tell also the orifice dimensions come from the aviation world. IMO the "spec." is not very exact but probably good enough. One might think a chart or table of flowrate and delta pressure exists somewhere but as mentioned what they have now is good enough.
dannobee 10-25-2021 07:06 AM
The spec for the orifice size is in the FAA regs.
"For an engine cylinder having less than a 5.00-inch bore; 0.040-inch orifice diameter; .250 inch long; and a 60-degree approach angle."
The approach angle and length are critical for comparisons between two different leakdown testers.
hcoles 12-09-2021 07:26 PM
To close this out. Buyers never asked about a compression test after seeing the leak-down test. So I didn't retest with a hot or warm motor. Car sold. Issue is resolved.
