Valve spring question
2.0L 67
Are the valve springs progressive. I've read they are and a proper install is required. I cannot see this on my springs. Eg anyway will do ?? Thanks lyndon |
yes they are, the tight wind is against the head.
Im having difficulties in seeing a tight wind ??
Lyndon |
Normally the tighter wind is pretty easy to see. Maybe try to post a picture?
Take a 1/4” drill bit and spiral it to each end you will see the difference
https://uploads.tapatalk-cdn.com/202...b100d5169a.jpg Sent from my iPhone using Tapatalk |
Now that makes sense Lyndon |
Yep it's progressive.
Learn something every day. So easy to see once I used the drill bit and marked it. The white mark nearest the bottom is the bottom when installing. A side note I can't find any info on spring fitment in Wayne's book http://forums.pelicanparts.com/uploa...1632442288.jpg Thanks again Lyndon |
what do you mean fitment? installed height?
No about the spring orientation
Lyndon |
| All times are GMT -8. The time now is 05:00 PM. |
