Pauter rod question.
I'm all fitted and happy.
I have noticed that the rod at the little end is not consistent. I would have thought these rods would be perfect out of the CNC. The amount removed is quite remarkable. I only noticed this after my cases have been sealed. Lyndonhttp://forums.pelicanparts.com/uploa...1632989827.jpg http://forums.pelicanparts.com/uploa...1632989827.jpg |
Following
Sent from my iPhone using Tapatalk |
Did you weigh them prior to installation?
Yes.
Reply from Pauter. All good. Totally normal.. Just needed that reassurance. Lyndon |
Pauter
Looks like one rod was replaced.As long as the weight and balance is good I would not worry.How was that aluminum intermediate gear I sent you?I never heard back from you.Fred
Fred.
All good with the gear thanks. Lyndon |
At least they didn’t remove it from the large end
| All times are GMT -8. The time now is 02:47 PM. |
