Thread size for flywheel lock?
What is the thread size on the hole in the Pelican engine fixture where the flywheel lock mounts? I can't get anything I have lying around to start in easliy, but maybe it's just gummed up with paint.
David,
I can't tell you offand what the thread size is, but I know mine *was* not only gummed up with paint, but the threads were poorly tapped. I re-threaded them. Unless someone can beat me to it, I'll try and dig out the yoke later today, and post what the thread size is. |
If you're talking about the Porsche yoke, the threads are 8mmx1.25. I put a stud in mine and I use a wing nut to hold the flywheel lock on.
-Chris (Good luck finding a 8mmx1.25 wingnut..) |
| All times are GMT -8. The time now is 01:26 PM. |
