Rod bearing/bolt life
I have approx 15 hrs on a track motor. Shifts at 72-7500 rpm, 10.5 to 1 compression ratio. Stock rods with ARP bolts and GT3 rod bearings. What is the refresh frequency on a track engine. Thanks, Bob
Old 02-23-2022, 01:40 PM
Jeff Alton's Avatar
What motor?
www.turn3autosport.com
Old 02-23-2022, 07:40 PM
Right, 78 911 3.0 aircooled
Old 02-24-2022, 06:35 AM
(man/dude)
Jonny042's Avatar
Unless it's a highly competitive class I would just keep an eye on the oil and leakdown numbers and run it till it shows symptoms of a problem.
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 02-24-2022, 06:45 AM
Ingenieur
It’s all about the over-revs buddy. Botched downshifts. I would consider a hard 7200 rev limit, and a max RPM telltale to keep an eye on those. Force on the bolts goes up with the square of the speed: force = RPM^2. No hard and fast rule on how many 7500 RPM trips it has in it, but the unloaded condition (downshifts) is the thing to count, not hours when it comes to rod bolts.
Old 02-24-2022, 11:14 AM
