-   -   Factory Spec for valve spring clearance? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/110522-factory-spec-valve-spring-clearance.html)
WERK I 05-13-2003 09:58 AM
Searched all the posts and manuals, but can't seem to find the spec for coil clearance(aka coil bind) at max lift. Seem to recall it being .015", but not sure. I'm using a Web 158 grind (SC type profile) on my 930 with factory springs...just performing a sanity check. Thanks
