New engine start up question
My 2.0L has been rebuilt. ( Cases apart )
On start up do I need to drain the oil and change the filter after a 20 min run ( I do not have new cams ). My thinking. The filter will filter perfectly up to 1000kms. At the best drop the oil at 20 mins of running on the hoist. ( Or less before I drive it and bed the rings in ) ( I have some cheap 15 / 40 and 20 / 50 in my garage that I'm going to start it with. ). It will has a big service at 1000 to 1500 KMs Oil. Filter. Valves. Thoughts Lyndon |
Can't answer, but best of luck! I think there are all sort of methods out there. pick one and thumbs up.
start up
If your rings are new you need a non detergent oil or the rings will not seat.I usually run the oil for 3-400 miles then do a leakdown test.Fred
Castrol GTX. ?
I usually change the oil after the initial start up - say 20 minutes or so depending on the engine and if the cams require running in. I use a cheap non synthetic 20w/50. I drain it, replace the filters and use a a quality running in oil for 1000km or so. I’ll then use a high quality non synthetic 20w/50 oil for a couple of thousand. Up to you if you go to a full synthetic or not after that. I stick with Brad Penn 20w/50 non synthetic but up to you. I think the most important thing is the initial oil and filter change and then a quality running in oil. From memory, you are in Australia also so you can access Penrite running in oil which is what I use. Just be mindful not to go to a synthetic oil too soon.
Cheers Todd |
After waiting 5 weeks for a new cooler it's running.
Post build thoughts. My engine had good heads but the barrels and rings were worn so it's a bit hard to judge but ?? I have fitted JE pistons and Pauter rods. These are the only improvement on performance. Its night and day. Revs so freely and smooth. Its another step up. I can highly recommend these. I just started it and drove it to bed the rings. After 500kms I will drop the oil and filter. Do another 500. Oil and filter. Valves. Timing. And set the carbs. Done 300kms now it goes nice and hard. Thanks lyndon |
After 300kms, it's run in if it ever is going to be.....I'd dump the break-in oil now and check the valves at 1000kms and be done with it.
The only "wear in" item here is the rings and cylinder walls and they are already worn in. |
So synthetic at 300 KMs
300 kilometres, that’s only 186 miles, personally I’d run the break in oil longer than that it’s not as though break in oil doesn’t provide adequate lubrication, yes the majority of the break in happens in the first 100 miles but the process won’t be complete then.
I’d change the oil after the initial start up then again at 500 miles then go synthetic at 1000 miles, thats 800 and 1600 Kilometers. That would keep clean oil in the engine as much as possible. But each to their own I suppose. |
Scotland.
You must be cold 😁 |
Never let the engine just idle while breaking it in. Vary the load and the RPM over the first hour and keep it above 2000 RPM. This will break-in the cams/rockers if they are new and will vary the ring pressure against the cylinder walls. You don't want to overheat the rings with constant high loads. |
Wow. I can't even begin to imagine that.
My garage has a swampy for the hot weather and gas for when it gets cold. Beer sounds good but. Lyndon P |
The way I’ve broken in engines in the past was to (once it’s up to temperature) vary between full throttle and trailing throttle as much as possible but limit RPM for the first couple of hundred miles (4000 ish) then gradually increase RPM over the next few hundred miles through to max RPM. During my training I was told to refresh the break in oil at 500 miles then remove it at 1000 miles, but I’m an old git so maybe that’s not the recommended way now |
Never heard of a Swampy I’m presuming it’s air con, I’ll just open my doors for that in the summer 👍 |
Wish I had your problem it’s 4 degrees here now |
What is happening at 6000 that doesn't occur at 4000? I see a reason for getting the engine up to temperature before getting the hammer down. I see a reason for doing pulls progressively up to higher and higher rpms to get a feel for the engine. But I fail to see what damage that can occur going to redline in the first 10 miles, compared waiting 1000 miles. I've given this some thought but haven't really found an answer, so on the few rebuilds I've done I have gone full tilt as soon as the engine is warm and has ok fueling. |
I would be interested in what views a professional engine builder has on this subject if Neil, Henry etc happens to read this. |
| All times are GMT -8. The time now is 06:51 PM. |
