Better Cam option
Currently looking for a better cam option for my low hour 2.0. race engine. Well put together , but under cam'd race engine. Currently Web 120/104.
I currently also have a 134/135 or 171/149 options on shelf. Looking for a little more top end, which means above 7-8k power. I know the 134/135 is basically a 906, but curious about the 171/149 in small displacement motor. The other concern is pretty big valve lift difference 120/104 Vs 133/135. The other option lift is very close. |
Have you spoken to Web about your engine goals?
Also drop a note to John at DRCamshafts (he posts here) to see what he thinks. Cheers |
As Jeff said, give Web a call. Seeing as you have several of their grinds on hand, they'd be a good one to talk to see which would best fit your application.
| All times are GMT -8. The time now is 02:15 PM. |
