David Gouk Race Engines
993 Coil On Plug Valve Covers
Hello, Ive been beavering away on a coil on plug project for all the cam carrier variants, with a real focus on quality and fit. First in my Hardinge Bridgeport VMC is the 993 type.
All 4 covers are different so we get a good fit around all areas. They are made from European sourced 6061, with no corners cut in the machine time to get the best finish. I will upload more pics as I manufacture the different variants. ![]() ![]()
Those are sweet! What coils have they been designed to fit?
Very cool project!
That’s a really cool project.
What hat are the specs on the engine build?
81 SC 3.8 Conversion 2017 Macan S INSTAGRAM @tail_spinz |
https://m.facebook.com/DAVIDGOUKRACEENGINESNO1/ |
Drive it like u stole it.
I’m very interested in a set for a 1976 930/50 twin plug turbo motor. Can you provide a cost estimate yet?
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
I think there is probably interest from quite a few people, myself included. Not having messed with VW coils before, they will fit both 12mm and 14mm spark plugs?
Still working on that, But they will be competitive. I will have them done in January. If you message me I can email you some screen shots of the CAD model . Thanks for the interest. David Gouk.
The Audi coil is a smart coil, just like a Porsche coil. So no separate igniters are required. Yes they fit, 10, 12 and 14, as long as the plug has a 16mm/5/8 hex size. The VW/Audi coil connectors are readily available for your engine loom. In the 12mm, NGK plugs the first 2 letters signify 12mm thread/16mm hex Hope this helps. Thanks David Gouk ![]()
Production continues on the Bridgeport V1000.
Impressive beyond words !
1986 Targa Guards Red 2021 MT09 SP |
