-   -   Best current rear main seal ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1108453-best-current-rear-main-seal.html)
Lyndon302 12-10-2021 08:49 PM
911 1967.
Rebuilt engine. 200 miles. Just got home 1st impressions the rear main is running out quite bad. Up until now it's been dry.
Elring made in Italy fitted.
Will investigate on Monday but until then what seal is recommended.
Lyndon
SorenDK 12-11-2021 11:27 AM
I recommend original Porsche… had same problem as you until i fitted original
Lyndon302 12-11-2021 12:56 PM
Lyndon
356911930 12-13-2021 08:10 PM
Lyndon,
Did you install the rear main seal dry or with some type od sealant?
Thanks,
Rahl
Lyndon302 12-13-2021 08:11 PM
Sealant.
See my new thread. The seal is not the issue ?
http://forums.pelicanparts.com/porsche-911-technical-forum/1108643-mystery-oil-leak-questions.html
Lyndon
356911930 12-17-2021 09:10 PM
Most recommend installing the rear main seal dry.
Rahl
