David Gouk Race Engines
993 Coil On Plug Valve Covers
Hello, Ive been beavering away on a coil on plug project for all the cam carrier variants, with a real focus on quality and fit. First in my Hardinge Bridgeport VMC is the 993 type.
All 4 covers are different so we get a good fit around all areas.
They are made from European sourced 6061, with no corners cut in the machine time to get the best finish.
I will upload more pics as I manufacture the different variants.
Old 12-10-2021, 11:46 PM
Evan Fullerton's Avatar
Those are sweet! What coils have they been designed to fit?
Old 12-11-2021, 08:25 AM
Very cool project!
Old 12-11-2021, 09:15 AM
Thanks Evan, Initially I tried to use a Porsche coil, Unfortunately the stem of the Porsche coil interfered on the 993 cam housing on number 1 cylinder, So I went with the AUDI R8 coil, They are retained by a lip machined into the cover and are located by 2 rubber keys on the coil. You will see the 2 slots on the covers. The Audi R8 coils are well proven and the retention not using bolts is nice
Old 12-11-2021, 08:05 PM
That’s a really cool project.
What hat are the specs on the engine build?
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 12-11-2021, 08:47 PM
Hello, ive got a few on the go currently, but these valve covers are for a Singaporean customer. They are 80.4 x 102mm engines. Billet heads, custom cast intake manifolds with twin drive bywire throttle motots etc. Alot of one off custom stuff. Here is a link to my facebook page. Im based in Auckland New Zealand.. my main business is building single seater engines for F3 spec cars and Porsches as time permits.
https://m.facebook.com/DAVIDGOUKRACEENGINESNO1/
Old 12-12-2021, 12:28 AM
Drive it like u stole it.
jonesb930's Avatar
I’m very interested in a set for a 1976 930/50 twin plug turbo motor. Can you provide a cost estimate yet?
____________________________
Bill Jones
Jupiter, FL
77 Euro 911 3.0 Wide Body - under construction
http://www.flickr.com/photos/rennsport/collections/72157618856489537/
Old 12-12-2021, 04:57 AM
I think there is probably interest from quite a few people, myself included. Not having messed with VW coils before, they will fit both 12mm and 14mm spark plugs?
Old 12-12-2021, 05:57 AM
Still working on that, But they will be competitive. I will have them done in January. If you message me I can email you some screen shots of the CAD model . Thanks for the interest. David Gouk.
Old 12-12-2021, 12:34 PM
Hi Evan,
The Audi coil is a smart coil, just like a Porsche coil. So no separate igniters are required. Yes they fit, 10, 12 and 14, as long as the plug has a 16mm/5/8 hex size.
The VW/Audi coil connectors are readily available for your engine loom.
In the 12mm, NGK plugs the first 2 letters signify 12mm thread/16mm hex
Hope this helps. Thanks David Gouk
Old 12-12-2021, 01:12 PM
Production continues on the Bridgeport V1000.
Old 12-12-2021, 02:24 PM
Location: Just a little north of 13669/Nation's capital
Send a message via AIM to brighton911
Impressive beyond words !
1986 Targa Guards Red
2021 MT09 SP
Old 12-18-2021, 11:25 AM
