Technical measures - cylinder headstuds
Hi Guys
I need som help with technical measures. I want to make a drilling fixture for repairing the head stud thread. The case is a 7R magnesium from a 2,7 liter engine. Does anyone know the exact measures/specifications of placement and distances between the headstuds + cross measures? I have attached a picture - basically I need the distances marked with red lines. All measures from center of hole :):) Thanks and have a great new year Søren http://forums.pelicanparts.com/uploa...1640959901.jpg |
80mm x 80mm. They form a square.
And then there was a race engine with something in between - 83mm? Must be very scarce.
However, the engine mentioned is a 2.7 7R, and the photo must be just for illustration, as it is a 1R. |
You can put a stud in each hole. Then measure from the inside of one to the outside of the other.
This will give you the center to center measurement. |
| All times are GMT -8. The time now is 05:52 AM. |
