2.7 engine case..align honing or boring
Hi everyone ... Just by curiosity, how much can cost a line bore machining on a 2.7L? I demantaled my case to measure the crank and see if it was in a good shape and with the plastic gage i got 0.025 to 0.038mm spec are between 0.001 to 0.072mm. But some bearings have a lot of wear tight spots and after i reclosed the case, i have the feeling the crank is more difficult to turn by hand than before. So i suspect the case has warped and will need to be align. Thanks
Ollies is one of the shops that can handle what you need done. Here's their price list
https://olliesengineering.com/services-pricing/ One thing to note is that the mag cases are known to deform as you mention and sometimes need multiple things done to bring them back. |
I just had a 2.7 case machined by Competition Engineering and it came out to around $3.5k for everything that was needed. A friend had a 2.7 machined by Ollies a year or two ago and it was in the same price range. There is quite a bit to do, if you are going to do it properly.
David |
I would plan on 3k plus or minus 750 dollars.
Just the reality of a mag case motor. |
| All times are GMT -8. The time now is 11:11 PM. |
