Cams and rockers
]I recently purchased a 3.2 hot rod motor. With approximately 30k mi. My builder says there’s damage to the rockers. Currently running rsr cams with pauter rockers. Previous owner thought the cams were a little peaky. My builder suggested different cams with a broader power band and rebuilt Porsche rockers. I’m curious. What’s the difference between rockers and also what would be a good cam choice ?
Any input would be appreciated!
Old 01-20-2022, 08:00 AM
H-viken's Avatar
Did say what type of damage? Pauter rockers aren’t cheap I remember correctly
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452)
911E Coupe -70
Carrera 3,2 -84 Sold
Old 01-20-2022, 08:33 AM
My understanding is due to wear. I suppose cams can be reground and rockers rebuilt.
Old 01-20-2022, 09:26 AM
Brew Master
cabmandone's Avatar
Seems like cam and rocker wear to the point they need replaced with 30K on them would indicate other problems. Maybe the oil tubes in the cam towers are plugged and the cams aren't getting proper oil?
Nick
Old 01-20-2022, 10:16 AM
With hot cams.and high dollar rockers, they may have also used stiffer valve springs. Stiff springs are known to accelerate wear on the rockers and cams.
Old 01-20-2022, 10:37 AM
I believe that is the case Thanks guys!
Old 01-20-2022, 11:36 AM
(man/dude)
Jonny042's Avatar
I've spent quite a bit of time looking at cam profiles lately and yeah, if they are RSR sprint cams they are pretty racy. Maybe too much so, depending on what the motor is being used for. If that's 30K race miles at 8000RPM then it's just regular wear
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 01-20-2022, 02:01 PM
It's a 914 ...
stownsen914's Avatar
That's what I was going to say
Old 01-20-2022, 06:59 PM
]Makes a lot of sense. The motors going in a 73 track car with minimal street use. I’m all about driving it vs. rebuilding. Thinking 964 cams and stock rockers might be a reliable way to go. Thanks for the input guys!
Old 01-21-2022, 07:03 AM
targa72e's Avatar
964 cams may be too mild if the rest of the engine was built around sprint cams. This could result in to much dynamic compression. Generally you would be looking at also running very a very high compression ratio with sprint cams. You might want to post more information about the rest of the engine build. I would also be a good idea to talk with the company's that supply camshafts about your engine details and desired outcomes, they can probably make a good recommendation.
john
Old 01-21-2022, 11:49 AM
Puny Bird
Mark Henry's Avatar
The wear is likely the springs are too heavy or running to close to coil bind, I'd want to do a full check of the heads.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 01-21-2022, 04:35 PM
It's a 914 ...
Re: cams, it may be a good idea to talk to one of the cam grinders and discuss what you're looking for in terms of usage, sportiness, etc. RSR cams would indeed be a bit peaky for street motor. 964 cams might be a bit mild, especially if the engine is carbed or ITBs.
Old 01-21-2022, 05:14 PM
