Compression ratio advise
Posted over on technical but didn’t get any answers.
Hi. I’m about to start rebuilding my 3.0SC, I’ve already got some 98mm cylinders that are going for a re plate and hone , I’ll get the cams reground to suit whatever o need but I’m looking at new 98mm pistons, 70.4mm stroke and 22mm pins. I like the price of Wossner but their 11.1 CR is too high “possibly, Carrillo do a 10.1 and JE have several but are a bit more money. I’m UK based so import costs are steep but petrol octane is high so I can get away with higher CR. I’ll be fitting carbs, either PMO or Webber’s. I would like some solid advise on piston choice and CR for my needs. Thanks in advance. |
I'm seriously considering the Carrillo 10.5 CR pistons for my 3.2L SS
David |
I think there is another thread also
