Compression ratio advise
I posted this over on technical but was told it might get better info here.
Hi. I’m about to start rebuilding my 3.0SC, I’ve already got some 98mm cylinders that are going for a re plate and hone , I’ll get the cams reground to suit whatever o need but I’m looking at new 98mm pistons, 70.4mm stroke and 22mm pins. I like the price of Wossner but their 11.1 CR is too high “possibly, Carrillo do a 10.1 and JE have several but are a bit more money. I’m UK based so import costs are steep but petrol octane is high so I can get away with higher CR. I would like some solid advise on piston choice and CR for my needs. Thanks in advance. |
| All times are GMT -8. The time now is 03:42 AM. |
