Well, the plot thickens, the specs are not a typo..... Molnar doesn't make a 964 Rod at all, it's a 964 RSR rod. Which is a 964 rod with a 993 width small end. From what I can tell this is useful if you wanted to use 993 pistons and a 964 crank.
They also make a 993 Rod which also fits 996 Turbos. What they don't make is a 3.2/3.3/964 rod. Unless someone knowledgeable can advise me that the narrow pin end of the 964 RSR spec rod is OK to use with the off the shelf 3.2/3.4 JE pistons I've ordered, I'm going back to plan "A", to use rebuilt and balanced stock rods with ARP bolts. |
The bigger picture on this motor is it's a street/auto-x motor and I've chosen to give it a nice meaty torque rich powerband, which means it's never going to be an 8KRPM screamer. $1700 Aftermarket rods are most definitely overkill. But if I can install something for a few hundred bucks more than stock rebuilts and lose 100g+ per hole of reciprocating mass, that would be money well invested. As far as connecting rods costing money down the road? Not sure how that is, as we are discussing viable options. |
Your choice should always be based on your engines performance. Then budget.
I assume the engine's performance is going to be around the mid 300 BHP? That's around 55- 60HP per cylinder/rod/pin/pin boss. Not a lot. The stock rod will work if rebuilt correctly. The weight will be the only consideration. Many of the current options are still heavy for this type of engine. You stated a "meaty" torque band. I'm not sure what that means. You will be limited to the amount of torque produced by air intake limitations and displacement. The engine's VE is going to be at the lower end of the scale. So what you need to consider is the time it takes for the engine to reach the usable torque. The quicker you can rev the engine into the Torque that will accelerate the car forward the better. This is where the component weight makes a difference. You need to consider trying to get all cylinders making the same torque. Heavier rods won't do anything to help get more air into the cylinders. Lighter rods will cost $$$. another factor to consider now is, delivery time. You may be a shock on how long it will take. |
The below quote is a better overview of the plans from this thread: http://forums.pelicanparts.com/911-engine-rebuilding-forum/1109850-hot-3-4-build-max-safe-rpm-stock-rods-w-9mm-arp-bolts.html Quote:
The ECU, 46mm ITBs and 12 COP units are in hand and I'm working on the heads right now as parts trickle in from around the world..... yes the supply chain issues are real. And yes I'm already over budget!!!! I'm aware that the phrase "building a 911 on a budget" makes as much sense as "Fuc%#@ for viginity"....... The car also has close ratio gears in 2nd and 3rd and weighs 2335 pounds empty so getting to that torque is a little easier than some cars. |
Hi Jonny,
What rods did you end up with now for your hot 3.4 build, are you going to stick with stock ones? I think that Neil is working with an Italian company to produce some that are strong enough for a NA application and lighter than Carillo and Pauter? Not sure about the price however.. Cheers, Lukas |
| All times are GMT -8. The time now is 01:14 AM. |
