More updates...
Gauges from John Bell look so good I'm afraid to unwrap them! No clock as going with the obnoxious oil pressure light :) Also got a few pieces gold cad plated, turned out great! I prefer it to zinc if there's a professional shop around that can do it - getting rare these days...http://forums.pelicanparts.com/uploa...1652977433.jpg http://forums.pelicanparts.com/uploa...1652977433.jpg |
Deleting bumperettes and flares going on - fitment is exactly what I wanted with the wheels. A small drop and should be good to go.
http://forums.pelicanparts.com/uploa...1652998887.jpg http://forums.pelicanparts.com/uploa...1652998887.jpg http://forums.pelicanparts.com/uploa...1652998887.jpg http://forums.pelicanparts.com/uploa...1652998887.jpg |
And welded, time for prep and paint!http://forums.pelicanparts.com/uploa...1653755889.jpg
Primer is on! Another round of block sanding to go before paint.http://forums.pelicanparts.com/uploa...1654830458.jpg
http://forums.pelicanparts.com/uploa...1654830458.jpg http://forums.pelicanparts.com/uploa...1654830458.jpg |
Nice Build…
I have a similar build pending time to get to it, please let us know how the engine and short geared 915 work together.
I am particularly interested in the 915, I kept 1st stock since it’s low enough and went with 15:30 (2.00) 2nd, 21:31 (1.476) 3rd, 24:27 (1.125) 4th and 28.24 (.857) 5th. I was worried about high rpm’s on the Highway in 5th, so I kept 5th close to stock. |
Curious if anyone knows how much a set of JE 9.5:1 P&C run these days? LN has them for 6k+ is that the going rate now?? |
This is what I'm seeing. Are there any other options?
https://lnengineering.com/shop-by-model/porsche-911-2-7/porsche-911-27-92mm-nickies-inc-95-1-je-piston-set.html |
Sent from my SM-G991U using Tapatalk |
A few bits and bobs trickled in so couldn't help but mock them up. Really liking the smoked rain hats, light too!
http://forums.pelicanparts.com/uploa...1658377220.jpghttp://forums.pelicanparts.com/uploa...1658377220.jpg http://forums.pelicanparts.com/uploa...1658377379.jpg |
I built my 1971 911S that weighs 2000lbs with a 1976 2.7 mag case to a 2.8 with J&E 92mm pistons 9:5.1 With a mod S cam and 46mm PMOs with ported heads. RSR headers and 997 GT3 muffler. Had my gauges also done by John Bell. 7:31 R&P. Very quick! Car weighs 2000 lbs.Haven't had it dyno yet, but expected to hit 250hp. Good luck with build.
Definitely reducing some weight. HVAC, rear seat delete, lightweight ST style front seats, sunroof delete etc. Hope to be around the same weight as yours all said and done. |
Save $3500 - replate your cylinders and use JE pistons
This is the route i am going, along with Craig Garrett's head work, including twin plugging and X factory EDIS ignition, MS2 Megasquirt with PMO EFI. (With a lot of help from "Trackrash". Regards, chris |
Diverterts. Light weight RS bucket seats. |
I had the base plates gold cad plated as well to add to the look :) |
In other news, tackled my floor sound deadening yesterday - wasn't too bad with a hot air gun and a sharp chisel. Came off clean and thankfully no rust! Removed the interior firewall sound pad as well, that thing is heavy... |
Ok first minor snag hoping I can get some clarification from those who have walked in these shoes before...
While mocking up the Guard LSD, found out I will need longer ring gear bolts. Gave Matt from Guard a call and confirmed there is a specific LSD bolt set I can buy from Porsche but he couldn't remember the exact part number and silly me I forgot to write down the number he thought it could be. Looks like the ideal length would be around 25mm but I can't find any Porsche ring gear bolts that are 12x25mm long. The closest I could find is 928 332 276 03 which is 12x21mm - would that work for a '77 915? Stock bolts are 16mm and far too short. https://www.pelicanparts.com/More_Info/92833227603.htm?pn=928-332-276-03-OEM Some pics of a stock bolt mocked up to the guard unit, any guidance is appreciated!http://forums.pelicanparts.com/uploa...1660618946.jpg http://forums.pelicanparts.com/uploa...1660618946.jpg http://forums.pelicanparts.com/uploa...1660618946.jpg |
| All times are GMT -8. The time now is 04:25 AM. |
