sloppy rocker arms
How much side to side play is ok in the rocker arms. They can also be rocked side to side maybe 20 or 30 thousandths. At what point should they be rebushed?
Dennis H. 72 911E 2.7 RS stuff
72 911T with a 2.7(Sold 5-13-2011)
2012 Kona Blue Metallic Mustang GT Convertible 6spd
67 Mustang coupe future SVRA group 6 car
63 Falcon hardtop 302/4spd
Old 05-25-2003, 07:34 AM
Dennis. I am not sure about what you mean by side to side? The rocker should be a easy slip fit on the rocker shaft. They do slide along the lenght of the shaft quite a bit.
Old 05-26-2003, 07:27 AM
Ok, that makes me fel a little better. They can move side to side a little bit. I also feel as though I can rock them, grab the end on the cam and wiggle it. This part is not sliding it is a little rocking side to side as if the bushings are worn. Well anyway, i think my noise was coming from the failed tensioner I also discovered. I did notice the valves were generally at about .006, so they need to be adjusted as well.
Thanks 5axis
Old 05-26-2003, 07:34 AM
