Best source for 3.2 crank reconditioning
I have a 3.2 crank that needs to reconditioned. Spun the #4 rod bearing and the journal is out of round, out of spec. Needs to be reground, nitrided, polished etc.
Who would you recommend to do this work? regards, al PS: I do have some good sources, but would like to research the alternatives, based on your experience |
For other cranks, we have used Marine Crankshaft with good results and reasonable turn around times. Have not sent them an aircooled crank but I believe Henry may use them for that.
Cheers |
I had Marine go through my 3.0L SC crank years ago and David Eden was a great guy in the process. No nonsense and extremely knowledgeable.
Marine cross-drilled it, plasma nitrided, straightened and polished the journals, balanced it (because I had it lightened- not necessary and probably not recommended by most) and tapped all the plug holes for set screws to make it easier to clean in the future. Yes the #4 main bearing is grooved and some will say grooving the bearing is better. I figure if the #1 main journal is grooved originally, probably not the end of the world if the #4 is grooved. http://forums.pelicanparts.com/uploa...1604423538.JPG http://forums.pelicanparts.com/uploa...1604423538.JPG http://forums.pelicanparts.com/uploa...1604423538.JPG http://forums.pelicanparts.com/uploa...1604423538.JPG http://forums.pelicanparts.com/uploa...1604423538.JPG If shipping wasn't so expensive and sketchy nowadays, i'd send Marine another one for my 3.2L rebuild. I believe Marine is the company who, last I heard years ago, manufactures Henry's Supercranks? |
Depending on what you are building here is another option. You can have the 3.2 rod journals turned down to 3.0 size. This allows you to use 3.0 (or titanium Pankl gt3) rods. These have the advantage of bigger (stronger) rod bolt and longer rod for better ratio. You need to have pistons made to work with longer rod but can also go with 22mm pin at same time for less weight.
john |
I sent mine to Turbokraft. Knife edged cross drilled polished and they matched individual porsche motorsports bearings to each journal. Took over a pound out of the weight of the crank.
http://forums.pelicanparts.com/uploa...1645657856.jpg http://forums.pelicanparts.com/uploa...1645657856.jpg http://forums.pelicanparts.com/uploa...1645657856.jpg |
Ive used Marine Cranks as well. He ground/welded 2 rod journals on my 993 crank. Cross drilled and grooved #5 bearing similar to Kevin's. David is great to deal with.
I found some pitting on 2 of the rod journals of a 3.2L engine crankshaft. Is this the sort of repair you had done on the crankshaft ? https://live.staticflickr.com/65535/...cbfbf6e3_b.jpg Thanks Engelbert |
Shipping is easy. A couple harbor freight moving blankets and a plastic crate. Line a black and yellow plastic crate from the box store with cardboard. Wrap the crank in cardboard and then roll up in the blankets. Zip tie the lid to the crate.
I had a spun bearing on the #5 journal. They welded and reground to spec. The crank was also cross drilled and grooved at that time too. The crank was given a once over prior to shipping back to me. Its hard to say how they may fix that. I looks deeper than what polishing will remove. Id give Dave a call at Marine Crankshaft to see what he thinks.
I would recommend wrapping the crank in blankets and cardboard as suggested. I used a wooden box which worked well. I have seen packages of cracks with the hanging half outside the box via the side. |
Dp
So cross drilling and grooving of #4 or #5 bearing will provide better oil supply to the rod bearings ? Is that what it is for ?
Thanks Engelbert |
e46 m3 crank, best rod bearing came from this journal. http://forums.pelicanparts.com/uploa...1671237652.JPG |
In your BMW case, crank was failing... Cause, who knows. But those E36/46 (if that is what you have) M3 engines are known for issues in this area...
The crank should not have journal material issues as a defect from the factory. Cheers |
Maybe if I'd zoomed into the picture even further you'd see how it's different then the 911 cam pitting for example, it had clean sharp rimmed edges with very steep walls almost 90 degrees into the holes, I think the machining took place with the pitting pre-existing. I mark every bearing on the way out (as well as top or bottom) so I can go back and check things later vs cylinder just for this sort of thing. |
OK, I made a box for the crankshaft.
https://live.staticflickr.com/65535/...3c693cbe_b.jpg This should do it. |
Approximatel Dimensions....
Rothaus, Do you remember the approximate dimensions of the the plywood box? Any special cradles or padding inside the box? Thanks. Tony |
Maybe that 3.2 crank was previously welded up and reground, leaving a few pits. Never seen that on a stock 911 crank.
| All times are GMT -8. The time now is 02:51 PM. |
