-   -   Smoothing/radiusing sharp edges on aftermarket pistons (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1113068-smoothing-radiusing-sharp-edges-aftermarket-pistons.html)
stownsen914 02-19-2022 06:42 AM
What’s the current thinking on smoothing/radiusing edges on aftermarket pistons like JE and CP? Seems like it makes sense to at least knock off the sharp edges around the valve pockets. How far do folks take this? My application is a track engine 12:1 compression.
A couple threads I found on the topic:
https://forums.pelicanparts.com/911-engine-rebuilding-forum/452068-sharp-edges-je-pistons.html
https://forums.pelicanparts.com/911-engine-rebuilding-forum/368320-jugs-slugs-confessions-je-piston-owner.html
http://forums.pelicanparts.com/uploa...1645281698.jpg
manbridge 74 02-19-2022 08:31 AM
Using cams with any overlap? Then I’d certainly follow Henry’s advice in the second thread you listed.
icarp 02-19-2022 12:03 PM
For the same reason for attending to the spark plug hole and threads.
The sharp edges can be a tremendous hot spot in the combustion chamber.
It is paramount to mitigate all possible hot spots , Then you can rely on the twin plug to do it's job reliably and consistently . Attend to ALL SHARP EDGES.
Just my thoughts
Ian
TimT 02-19-2022 01:38 PM
Debur the valve pockets, and massage the top of the valve pockets at the piston crown.
https://m.media-amazon.com/images/I/...L._SL1500_.jpg
or you can use a dremel or die grinder..
