3.3 turbo 79 Misfire 2000 to 3500 RPM in neutral. No misfire under load???
I have a 79 930 that free revving in neutral has a misfire from 2000 to 3500 RPM. It does not have a misfire under a load.
This is baffling to me as it has new plugs and wires the CDI box is original however.
Vacuum related?
Sent from my iPhone using Tapatalk Pro
http://9309700485earlyturbo.wordpress.com
Old 02-20-2022, 04:24 PM
You can fight that til the cows come home. Why does it matter if it runs nice when you drive it?
206 637 4071
Old 03-02-2022, 07:02 AM
Ingenieur
The fuel metering piston in the fuel distributor can also cause that kind of problem. At low airflow the fuel metering piston may be getting getting a little sticky.
Old 03-11-2022, 09:16 AM
