Uncertifiable!!!
Uwon's Avatar
Seniors Moment-Leaking Cover
My apologies, but it’s been ten years since I took apart this ‘86 3.2 motor so I have forgotten more than I remember!
I have this sweating cover just below the crank pulley (which is dry BTW). Cannot remember what it’s for.
It’s not clear to me what is behind it other than the seal. Can I simply remove the cover and replace the seal without screwing something up?
TIA
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 03-12-2022, 05:27 AM
Cover for the intermediate shaft
There is a green rubber seal that goes on it to replace original red
Lube it and install without pinching
Bruce
Old 03-12-2022, 06:25 AM
Uncertifiable!!!
Uwon's Avatar
Bruce, many thanks. The light just went on!
Johan
Old 03-12-2022, 06:57 AM
Johan
Are you certain the leak is not originating higher up? ie, crank pulley seal, or #8 nose bearing/case?
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 03-29-2022, 11:41 AM
Uncertifiable!!!
Uwon's Avatar
That was my first thought but then I noticed that the oily grime stopped just above the pic. Also, it’s dry behind the pulley. My guess is that the engine saddle cups the airflow upwards on the right side and helps the oil migrate upwards.
Cheers,
Johan
Old 03-30-2022, 04:44 AM
