-   -   info on this EFI slide valve setup (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1117163-info-efi-slide-valve-setup.html)
scootergt3 04-18-2022 12:50 PM
just bought a race car with this slide valve setup. can anyone advise of the brand? looking for info so I can sell it.
thanks in advance
http://forums.pelicanparts.com/uploa...1650311311.JPG
stownsen914 04-18-2022 01:29 PM
A 914 with slide valves - nice
scootermcrad 04-18-2022 01:40 PM
Can you tell if the slide body is cast and post machined? Sorta looks all machined, but the pockets (black?) almost look to have casting marks in them.
Nifty setup. How do they run?
jmz 04-18-2022 02:04 PM
possibly old ProTechnik slides.
scootergt3 04-18-2022 02:19 PM
everything looks machined alum. the dark arears are just dirt/grime. everything runs very nice, I just want to switch to carbs
Raceboy 04-19-2022 10:26 PM
Why would you switch to carbs if you have one of the best possible setups??
scootergt3 04-20-2022 04:15 AM
im not good with efi/ecu tuning... I like to keep it simple.
JmuRiz 04-20-2022 07:53 PM
I’d buy that for a dollar, cool looking setup.
75 911s 04-24-2022 11:51 AM
any idea what the valve size is?
safe 05-11-2022 05:13 AM
Get the car to a tuner with dyno and let him adjust it, then leave it alone.
Easy as that. Simple.
r lane 05-12-2022 07:24 AM
Depends on what engine management system you have and its tuneability. On another issue, how does one get around the pooling of fuel on top of the slide plates at idle. Once on the track, I am thinking maybe better atomization of the fuel. I have the option on my stacks to go either way and at present they are down below the slide plates. I am MFI, not EFI . Thinking out loud. Bob
r lane 05-12-2022 07:26 AM
Talking about the injectors installed above the throttle plates.
