#8 Nose bearing clearance
Hi, Can anyone tell me what an acceptable nose bearing clearance is?
Thanks Neven |
abit off center
I do not have the spec in front of me but one thing you want is clearance on the tighter side, this is one end where oil enters the crank, excessive clearance will reduce the oil flow
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Under the radar
Bore 31.041-31.084
Shaft 30.980-30.993 Clearance 0.048-0.104 Shaft wear limit 30.970
Thanks, My shaft is 30.976 so on the low side and I'm measuring the bore of a bearing I have here at 31.076 so clearance of 0.10, I'm thing a new standard bearing might be worth it
Under the radar
If you get a new one, let us know how it measures. As I am in the same boat.
Puny Bird
Last time I bought a #8 the tolerances were terrible, it was an aftermarket german bearing. I ended up DFL coating an used std. bearing I had.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Banned
Spec is 0.048-0.104mm (0.0019-0.0041")
Crank spec is 30.980-30.993mm (1.2197-1.2202") IMHE, they never seem to be on the tight end of the scale. |
I'm getting that impression, I think they are not really a 'bearing' per se but rather a collar for oil delivery to the crank, though I'd prefer a clearance smaller than the upper end of range
