#8 Nose bearing clearance
Hi, Can anyone tell me what an acceptable nose bearing clearance is?
Thanks Neven
Old 05-01-2022, 09:20 PM
abit off center
cgarr's Avatar
I do not have the spec in front of me but one thing you want is clearance on the tighter side, this is one end where oil enters the crank, excessive clearance will reduce the oil flow
______________________
Craig
G2Performance
Old 05-02-2022, 06:18 AM
Under the radar
Trackrash's Avatar
Bore 31.041-31.084
Shaft 30.980-30.993
Clearance 0.048-0.104
Shaft wear limit 30.970
Gordon
'71 911 Coupe 3,0L outlawed
Old 05-02-2022, 10:33 AM
Originally Posted by Trackrash View Post
Bore 31.041-31.084
Shaft 30.980-30.993
Thanks, My shaft is 30.976 so on the low side and I'm measuring the bore of a bearing I have here at 31.076 so clearance of 0.10, I'm thing a new standard bearing might be worth it
Old 05-02-2022, 02:31 PM
Under the radar
Trackrash's Avatar
If you get a new one, let us know how it measures. As I am in the same boat.
Gordon
Old 05-02-2022, 03:41 PM
Will do, I have asked the local group in NZ if they have any I can measure, Cheers Neven
Old 05-02-2022, 07:43 PM
Puny Bird
Mark Henry's Avatar
Last time I bought a #8 the tolerances were terrible, it was an aftermarket german bearing. I ended up DFL coating an used std. bearing I had.
'74 Porsche 914, 3.0/6
'72 Porsche 914, 1.7, wife's summer DD
'67 Bug, 2600cc T4,'67 Bus, 2.0 T1
Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend.
Old 05-03-2022, 07:40 AM
Banned
Old 05-04-2022, 12:39 AM
Spec is 0.048-0.104mm (0.0019-0.0041")
Crank spec is 30.980-30.993mm (1.2197-1.2202")
IMHE, they never seem to be on the tight end of the scale.
Old 05-04-2022, 08:49 AM
I'm getting that impression, I think they are not really a 'bearing' per se but rather a collar for oil delivery to the crank, though I'd prefer a clearance smaller than the upper end of range
Old 05-04-2022, 02:51 PM
