-   -   2.7 Hot Rod Engine Build (Advice Needed) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1118165-2-7-hot-rod-engine-build-advice-needed.html)
Aztim 10-04-2023 11:41 AM
Following this build!
Out of curiosity why not go with pauter rockers?
They're something like 1.5lbs lighter in all
Evan Fullerton 10-04-2023 01:24 PM
Except they aren’t anywhere near the 85g they advertise. I bought a set…….. significantly heavier than advertised.
http://forums.pelicanparts.com/uploa...1696450948.jpg
Aztim 10-04-2023 01:42 PM
Well that's lame
Has anyone contacted them about that?
Gonbad 10-14-2023 09:09 PM
Anything new Sirac? I have a 77 2.7L and I am looking at this build enthusiastically.
SiracHaile 10-15-2023 09:30 AM
Not too many updates but here’s where I’m
At for now.
https://uploads.tapatalk-cdn.com/202...4056447dc5.jpg
Installed a billet oil pump screen cover with clearance for the later oil pumps
https://uploads.tapatalk-cdn.com/202...9fa9f817c6.jpg
Installed the Clewett cam sync to match with my EFI ITBs
https://uploads.tapatalk-cdn.com/202...0a0b45a7c3.jpg
Installed the fresh oil cooler. Had to clean out the inlet since they left some sand in there. Always check others work.
https://uploads.tapatalk-cdn.com/202...a9106b4632.jpg
Mocked up the Burch headers. Not happy with the fit. The heater boxes interfere with the valve cover studs. Working with them on a fix or replacement but it’s been slow.
https://uploads.tapatalk-cdn.com/202...8aef979d34.jpg
Mocked up and trimmed the Sheridan shroud. It’s an okay fit, but wish I spent a little more for a better fitting kit with it pre-trimmed.
https://uploads.tapatalk-cdn.com/202...2fe163ea25.jpg
https://uploads.tapatalk-cdn.com/202...2957d41279.jpg
Mocked up the Throttle bodies from Clewett.
I will be experimenting adapting a drive by wire motor.
https://uploads.tapatalk-cdn.com/202...c14286e579.jpg
3d printing the drive by wire motor adapter before I send it off to get cut.
https://uploads.tapatalk-cdn.com/202...254885da24.jpg
That’s where it’s at for now. It’s all sealed up and I’m focusing on the body. Stripping it down to prep for sand blasting.
Gonbad 10-15-2023 07:38 PM
Thanks I appreciate it. Love the amber shrouds and engine surround. I am thinking of DIY pre-preg carbon/kevlar experimentation on forming a shroud and surrounds.
SiracHaile 10-15-2023 08:08 PM
If you do make one in carbon Kevlar I’d be interested
