915 clutch
What is the best clutch for a 915 transmission paired with a 930 EFI engine.
Looking for street and track/race application? |
clutch
Hey Rob. Do you have any thoughts on a clutch i should use?
Seems like nobody knows. Brian. I would appreciate your input. Still using your exhaust and its going strong. I get lots of complements up in Canads, always send them your email. |
Use one that slip easy so you don't grenade the 915
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
964 3.8L 300HP 275FtLbs with CMS race built 915 Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
housing and seizure of clutch to bell housing stopping engine during race = rivet failed causing flat spring to rotate outward lathing the bell housing and catching on the starter hole = Regards, Roy T PS: changing to Kennedy pressure plate . . . bell housing will be welded and machined by CMS ![]()
I had trouble with Sachs PP. Went to Kennedy ALU/ALU pressure plate with light diaphragm and street/race organic disc, clutch is heavy but works great.
Don't think the clutch is the issue, not sure a 915 will survive a 930 track car.
Location: behind the redwood curtain, (humboldt county) california
Kep
The KEP clutch, (Kennedy), is rated for 400 HP, is aluminum/aluminum, weighs a bit over 8 pounds and has triple riveted springs at each attachment point.
I'm using an organic Sachs disc and hope the diaphram isn't too stiff for my 74 year old leg chris |
With the usual CIS upgrades (turbo, intercooler, headers), went through "a number" (cough) of clutches in rapid succession - all, even the "upgraded" ones, broke free before peak torque on anything more than 1/3 throttle as soon as manifold pressure climbed. Difficult to ignore/miss that... My shop supplied a pressure plate stamped "ZF Sachs Race Engineering" and "88.3082.999.746" with a Sachs 4 puck friction plate. Pressure plate apparently the closest thing to an RSR pressure plate available at the time. Old for sale ad here for pictures/info: WTS: 915 Sport clutch & flywheel, WEVO coupler It required finesse on hill starts (pucks are either "in" or "out"), but never slipped under power. However, the extra pedal pressure caused almost every original part on the cable run (brackets, levers etc) to break within a month or three. And you'd be on the verge of crying like a little girl after 20+ minutes in stop-go traffic. Other than that, it was fine and I daily drove it for 6 years before going G50. IMO, you should really think about your output numbers, as others have advised.... My CIS 930/60 with upgrades made 350 ft/lbs at the wheels. Quoting my own "915 for sale" thread from long ago: Quote:
Despite always staying out of boost/rolling the throttle on progressively in the lower gears, the 930 did this to 2nd one day. Driving to work. In commuter traffic. You can't see it in this photo, but the base of the 5th tooth is also cracked & moving sideways...: ![]() So, yeh, not (re)using 40 year old gearsets would seem to be a smart move in this application too... At some power level, a G50 (or 930) transmission are the only real choices, because even a built 915 is just a more expensive grenade; you're one bad choice away from disaster. All the time. And it could still just go boom anyway. Don't even get me started on M8 bolts and undersized axles, flanges & CVs... I went G50 before EFI because seems to me that building a car where you can't use the power defeats the entire point... EFI will almost certainly pick up another 50-75 ft/lbs over CIS if you improve induction at the same time - at which point asking a 915 to deal is just denial/silly. The "oh, OK, it seems so obvious now" moment for me was comparing 915 and G50 parts on the bench.
'77 S with '78 930 power and a few other things. |
Yep. I agree with Spuggy. I have a upcoming backdate project with a 3.3 turbo.
Initially, my plan was to use a beefed up 915 but I recently came to my senses and bought a short box 930 trans. No matter how you slice it there’s no cheep options. But, IMO it’s going to save money in the long run. 915 rebuilds aren’t cheap.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband Wevo shifter, LSD. Next up, Cams, Heads and port work |
