-   -   I Need to Make My Engine a Little More Streetable. 365hp 3.6 (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1118508-i-need-make-my-engine-little-more-streetable-365hp-3-6-a.html)
GG Allin 10-22-2023 04:07 PM
Originally Posted by phunt (Post 12115071)
In the photo of the pistons the old one has the wrist pin deep into the oil ring where the new one has it below the oil ring. If you did not change the rod length nor the stroke how are you compensating for the extra 2-3mm height of the new pistons.
The distance from the deck of the piston to the top of the wrist pin is the same on both sets. CP used my old piston to spec my new ones. I think what gives it that illusion is the spacing and size of the two different ring sets. Same rods are being used and the deck height is currently right around 1.4mm.
GG Allin 11-04-2023 08:03 AM
Couple questions regarding cam timing. My cams have nothing on them to indicate top dead center. Is it woodruff key up? Also, I'm going with William Knight's spec for cam timing, he had told me a while back. 4.7mm - 5mm. Seems like a lot, but I'll trust what he says, his cams.
Classic 911 11-06-2023 09:24 AM
Following
Tippy 11-06-2023 12:57 PM
Convert everything to E85 and get the best of both worlds:
1. 100-105 octane
2. Engine cools under WOT
GG Allin 11-06-2023 03:19 PM
Motor is almost done, just waiting for final word on cam timing. It's been a learning experience.
http://forums.pelicanparts.com/uploa...1699312558.jpg
GG Allin 04-14-2024 11:23 AM
Motor is done. Just did a 25 minute break in. Lots of crackling and popping, but no leaks. Thanks to everyone that has contributed over the years. Without the search function here, I never would have been able to do this. This was my first and only engine rebuild. Thanks also to iCarp and William Knight for their long informative conversations. Take notes if either of those guys ever calls you.
Next is plate renewal tomorrow and then exhaust fab. Switching to a GT3 muffler that will be valved. I also need to clean up the ignition wiring.
http://forums.pelicanparts.com/uploa...1713118946.jpg
If anyone is looking for a Dynomax that is set up for S Car Go / William Knight headers......
A terrible video of a portion of the break in. Open headers....
<iframe width="560" height="315" src="https://www.youtube.com/embed/JVYxFlnb2kg?si=QpkcFhzU1myK6RHs" title="YouTube video player" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture; web-share" referrerpolicy="strict-origin-when-cross-origin" allowfullscreen></iframe>
GG Allin 04-14-2024 01:18 PM
This one had a little "sweat" coming from it. Gave it a slight snugging, hopefully it stops.
Also, I lost my turn signals since the car's been down. Not sure what's going on. Nothing indicated on the tach and neither right or left work. Fuses are fine.
http://forums.pelicanparts.com/uploa...1713125764.jpg
