Dashman0
Question Camshaft oil pressure restrictors
What is the orifice size difference between the standard and upgraded restrictor for the camshaft housings ?
Old 07-10-2022, 02:23 PM
Difference
I open the small hole to 5/32 for more flow but still holding pressure in the crankshaft.
First pic is old and new
Second picture is 5/32 bit in the old style compared to new
Bruce
Old 07-10-2022, 05:11 PM
Location: behind the redwood curtain, (humboldt county) california
New, first start recommendations
Hi Bruce,
I am beginning a high performance rebuild assembly. Do you think it appropriate to wait untill after break in to move to a more restricted - restrictor, given the critical nature of cam break in???
Thanks,
chris
Old 07-10-2022, 06:57 PM
Stock is 6mm, updated is 2.5mm. Many people split the difference and go with 4.5mm
Old 07-10-2022, 07:18 PM
Follow up question, re break in oil
Hi Bruce,
i know you have been there done this before, and am curious about "best practices" for break in.
After the initial "20" minute break in, with Driven 20-50, dump oil and filter, does it make sense to run the next 2000 miles with more Driven 20-50 brake in oil???
Given the importance of oil filtration to get rid of the break in debris, can you reccomend a better filter than the Baldwin 292???
thanks,
chris
Old 07-10-2022, 07:25 PM
tops911's Avatar
for what it's worth; I split the difference with a 4.5mm. When I bought my car it had the "updated" restrictors. After much research I decided to enlarge to 4.5mm
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 07-10-2022, 09:02 PM
