Topocalma
2.4T running well 5min, then deteriorating. Ignition off-on, car runs again well 5min
- EDIT - sorry I posted this in the wrong forum....
We recently removed the motor to do some maintenance. The K-Jetronic was not removed.
The car now runs well for approx. 5 min, then rapidly deteriorates. Turning the ignition off and on fixes the problem - for 5 min when it starts to deteriorate again.
We suspect an ignition problem which we are investigating but wanted to put this out there to find the issue faster.
Thanks a lot for your help!
1973 2.4T gemini blue
1977 3.0 Turbo slate grey
1973 2.4s motor rebuilding project
Old 06-20-2022, 08:04 AM
Tags
2.4t , ignition , running issue
