-   -   Just before heading off to Goodwood FOS…. (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1121124-just-before-heading-off-goodwood-fos.html)
BartdeBruijn 06-18-2022 02:06 AM
A few days before heading of to the great Goodwood FOS 911T 2.0 with weber 40IDA started running tough. Also dull popping in exhaust. Still running on all cilinders.
Today started her again, same story, rough through whole rev range.
To see if there was one cilinder misbehaving I measured the temp of separate headers.
1-2-3 were significant cooler then 4-5-6.
So carbs, right!?
Strange though if it is fuel(delivery) why whole rev range. Going from idle jet to main jet…..
Will pull carbs however all input is welcome!
Thanks,
Bart
john walker's workshop 06-18-2022 11:29 AM
Pull the plugs first and clean the idle jets.
BartdeBruijn 06-18-2022 01:39 PM
thanks, will do those first!
(maybe bit to enthusiastic/disparate to pull carbs apart already)
BartdeBruijn 07-20-2022 11:57 AM
Follow-up:
Pulled all 6 idle jets and as clean as possible, also all 4 fuel screens on bajonet bolts are fully clean!
As said, bank 1-2-3 was while warmed up on exhaust tubes +/- 50 C cooler than side 4-5-6. Engine was running rough and dull popping. Started within 20 minutes drive..
Could it be shifted cam timing as it is a whole bank 😬
Any other suggestions?
Regards,
Bart
Tom_in_NH 07-20-2022 04:58 PM
Worn throttle linkage for the carb on the 123 side?
Maybe check airflow side to side with a synchrometer.
