Fuel Pump Question
What are the pressure and flow values for the fuel pump for my 2.7 liter engine with webers.
Old 11-07-2023, 05:50 PM
It's a 914 ...
stownsen914's Avatar
Which pump do you have - stock or aftermarket?
Old 11-08-2023, 04:32 AM
buster73's Avatar
Carbs will need approx. 3.5 psi and up to 300 hp a flow rate of 20 to 30 GPH will be sufficient. If you still have a CIS pump installed, you can use it but will have to add a fuel pressure regulator.
Regards,
Guenter
73.5 911T, mod
Old 11-09-2023, 09:13 AM
stock pump
Old 11-13-2023, 12:14 PM
