Engine Stand Yoke
Good Morning,
Long time forum lurker here.. im starting a Carrera 3.2 tear down and rebuild project next month, i've been looking for a used 5 arm engine yoke (with the notches to clear a crossover pipe and engine oil cooler). Is anyone looking to part with one? |
Buy one, use it, and sell in the classifieds here for 80% of what you paid for it. Pass it along.
Cheers |
+1Jeff, then build a good strong engine stand to go with it.http://forums.pelicanparts.com/uploa...1656678172.jpg
Do you have plans/drawings for the above engine stand? I have a couple of HF engine stands and am looking to modify one for a coming 3.2 pull myself.
Agree with the buy and then pass along. |
I do have plans, will pull out and post jmd88
Stand plans
This is what I have. This stand is a copy of the engine stands Jerry Wood uses to hold up the heavy 930 plus. I asked if I could copy it when I was taking his engine building class about 2002. Markhttp://forums.pelicanparts.com/uploa...1657124238.jpg
You can also buy the rolling stand from Harbor Freight for like $75. The Porsche engine yokes are compatible with it.
We have 8 similar stands store bought. Look essentially the same. I will take pics of them tomorrow.
I use an OTC 2012A stand. Its very similar to the Jerry Wood design and it works with the yoke.
https://www.goapesonline.com/P/3022/23020OTCAlbEngineSt https://www.goapesonline.com/Content...ges2/2012A.png |
https://www.harborfreight.com/automotive/lifts-cranes-stands/engine-stands/2000-lb-capacity-foldable-engine-stand-69522.html |
thanks for the input all, i just went with the P01 knock off. After a few seconds of grinding, the yoke cleared my crossover pipe flange no problem. Now to get the heat exchangers off..
| All times are GMT -8. The time now is 05:14 PM. |
