Stahlwerks.com
jhelgesen's Avatar
Send a message via Yahoo to jhelgesen
Rod clearance on crank
I've looked and must be blind, but can't find the spec of what the tolerance of the rods moving side to side on the crank are.
I did a quick measure ment of the bearing journals and read 59.97 to 59.99, should be fine.
John Helgesen
Stahlwerks.com restoration and cage design
"Honest men know that revenge does not taste sweet"
Old 06-05-2003, 06:24 PM
Stahlwerks.com
jhelgesen's Avatar
Got my magnifying glass out, is it the clearance (rod/sidewall) .200 -.350?
John Helgesen
Old 06-06-2003, 04:21 AM
This must be a 3 liter crank as you didn't specify. The numbers you describe are for the main journals. According to a spec book, the standard main journal range is 59.971 - 59.990 mm. Your crank is 59.97 to 59.99 mm.
The connecting rod journal OD should be 52.971 - 52.990 mm (standard). The factory manuals don't list a rod side clearance that's readily obvious, but I think (please verify) it should be in the area of around 0.012 - 0.015" or thereabouts. Maybe Wayne has that info.
"Got my magnifying glass out, is it the clearance (rod/sidewall) .200 -.350?"
That's 0.008" - 0.013". That sounds about right. You eyeballed that? You're good.
Sherwood Lee
http://members.rennlist.org/911pcars
Old 06-06-2003, 12:17 PM
Author of "101 Projects"
Wayne 962's Avatar
I think he meant magnifying glass to read the very small print in the back of my book (it was the only way to make it fit!).
The rod / sidewall clearances are listed for all crankshafts on page 205. That's correct - +0.200 to +0.350, I believe I got that either from the factory manuals or the spec books.
-Wayne
Old 06-06-2003, 12:25 PM
Stahlwerks.com
jhelgesen's Avatar
Yep, real small print.
John Helgesen
Old 06-06-2003, 12:55 PM
Banned
snowman's Avatar
Only comment fot those of us over 40 years old, WHAT PRINT? YOu mean theres print on those pages? The only genuine criticism of the book I could come up with.
Old 06-15-2003, 10:45 PM
