Mahle Motorsport PS98015
Currently installing a set of subject cylinder kits and was hoping someone has calculated the dome volume. Any help would be appreciated.
Thinking you in advance,
Rusty
Old 04-06-2023, 10:55 AM
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Mahle-Motorsports spec's the crown volume at 38.5 CC's
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD
1976 914 2.0 Lime Green Metallic - Completely stock
Old 04-06-2023, 02:03 PM
https://www.us.mahle.com/en/motorsports/powerpak-pistons/porsche-powerpak-piston-kits.jsp
Select your engine and all the specs are there.
Old 04-06-2023, 02:07 PM
Thanks all for your direction.. I was odd be a few cc on the dome volume calculation. Feel better now. Still with 1mm of deck clearance I’m not to 10.1 cr.
Happy Easter.
Old 04-07-2023, 01:48 PM
One other item. Do the cylinder heads need to be opened a bit for the 98 mm and if so anyone have a method short of the machine shop?
Old 04-07-2023, 01:50 PM
PCA Member since 1988
The "slip in" kits do not require machining.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-07-2023, 02:38 PM
Jeff Alton's Avatar
Slip in kits do not require case machining. He was asking about heads. Take a good look at the set up, you *may* want to chamfer the head combustion chamber depending on your particular set up.
Cheers
www.turn3autosport.com
Old 04-14-2023, 06:04 PM
Thanks all, . Will chamfer the combustion chamber a bit to match the 98 vs 95 bore.
Old 04-14-2023, 06:16 PM
IIRC, the 98mm slip-in's are no wider at the top or bottom than the 95's. Es verdad?
Old 04-14-2023, 11:31 PM
Warren Hall Student
Bobboloo's Avatar
Most of the pistons they make these days have a flat land at the edge of the dome so a chamfer isn't needed. If the dome runs to the edge of the piston then you probably need a chamfer.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-24-2023, 09:13 PM
