Engine rebuild update . . .
Finally - - engine going back together . . . Crankshaft journal cut and replaced by Ollie's - rebored - etc... ARP case and rod bolts . . . New/Used 964 crankshaft from EBS - Reno . . . Waiting on piston rings to finish assembly . . . A few photos of assembly by Don Jackson Enterprise - Phoenix, AZ Regards, Roy T UPS Engine Case Assembled 1 11 2023 http://forums.pelicanparts.com/uploa...1673735901.jpg UPS Engine Heads Assembled 1 11 2023 http://forums.pelicanparts.com/uploa...1673735946.jpg UPS Engine Cylinders Measurement Documentation Work Area 1 11 2023 http://forums.pelicanparts.com/uploa...1673735974.jpg Regards, Roy T |
Finally - - engine back together . . . Crankshaft journal cut and replaced by Ollie's - rebored - etc... ARP case and rod bolts . . . etc., etc., etc. New/Used 964 crankshaft from EBS - Reno . . . Will add AFR system from AEM. A photo of assembled engine by Don Jackson Enterprise - Phoenix, AZ http://forums.pelicanparts.com/uploa...1676056870.jpg Regards, Roy T UPS Engine Assembled 2 08 2023 |
| All times are GMT -8. The time now is 04:29 AM. |
