-   -   78 SC Cam help (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1124056-78-sc-cam-help.html)
5.7 GT1 08-05-2022 09:22 PM
78 SC Cam help
I’m currently rebuilding the top end on my 78 sc. I’m excited to finally have another Porsche project again since my last build
http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/640609-taking-efi-plunge.html
In the process I decided to upgrade to L&N 3.2 SS cylinders and JE 9.5:1 CR pistons.
Here are the other changes being made to the engine (most being induction and exhaust) in the process:
-964 cams
-ssi’s
-dansk 2 into 1
-xfaktory Itb’s
-coil on plug ignition
-xfaktory ecu
My question is: can some tell me if my valve clearance is ok running the above?
I have already purchased all of these parts and won’t be making any changes if I’m fine on valve clearance. I’m also curious on recommended cam timing?
Thank you!
jac1976 08-06-2022 06:28 AM
You likely will get more traffic in the technical forum. Reaching out directly to KNIGHTRACE, icarp, and jpnovak will get you what you need. Not an exhaustive list, but it’s where I first would turn. Sorry I’m not more help.
5.7 GT1 08-06-2022 09:05 AM
Thanks jac
dannobee 08-06-2022 10:14 AM
You'll have to check P2V clearance to be sure, but JE's usually have pretty deep valve reliefs. There should be tutorials here on how to check if you're not familiar with the procedure.
Set 964 cams at 1.25mm.
5.7 GT1 08-06-2022 03:02 PM
Thanks for your advice dannobee. I was hoping someone has the same build specs and can chime in to help me understand if I don't need to worry about checking the valve to piston clearance. I guess I'm being lazy. Once I get started on assembly next week I most likely will be checking v to p clearance before setting the cam timing.
boyt911sc 08-07-2022 05:52 AM
Visual Test Inspection......
GTI,
Assemble your motor and do a visual test inspection using a dial indicator. You also need P7E/P7I valve compressors. If you don’t have these compressors, simply remove the valve springs from the cylinder head prior to partial engine assembly. Then measure the actual valve clearance with the crankshaft @ Z1 TDC and no cam tower installed.
Tony
jpnovak 08-07-2022 07:21 AM
964 cams will easily clear JE pistons.
but, If you are going with those pistons you should seriously think about changing cams to something else. A DC40-108 would be my choice. more midrange torque, more top end. Just better matched to ITB/EFI setup.
'78 SC 08-07-2022 08:07 AM
I ran 9.5 CR JE pistons (95mm) with the stock cam re-ground to 964 profile and had no clearance issues, just as Jamie says.
I still suggest you check the clearances, especially if you have done anything that could change deck height. I used the technique described in Waynes's rebuild book. Be sure to check throughout a full cycle (720 degrees of crankshaft rotation) since the point of closest approach between the piston and valves is not at TDC.
5.7 GT1 08-07-2022 08:23 AM
Originally Posted by boyt911sc (Post 11763635)
GTI,
Tony
Thank you Tony! This is really helpful.
5.7 GT1 08-07-2022 08:29 AM
Thanks Jamie, I would jump on a set of DC40-108 cams if they were available. Unfortunately, it seems to take months to get anything these days and I will have everything ready to assemble next week.
5.7 GT1 08-07-2022 08:35 AM
78 SC, That is good advice. I used Wayne's book to build my last motor (and will use it for this one as well), but it was a low compression 930 motor. I know that with a 9.5:1 CR I need to be careful with valve to piston clearance.
RDM 08-07-2022 12:28 PM
There is a lot of good buzz around William Knight's M1 cams, and he may have them in stock. He's very generous with advice after making you clearly identify your goals.
knightrace911@hotmail.com
615.969.4917
5.7 GT1 08-07-2022 02:57 PM
615.969.4917
Thank you!
I’ll reach out to him.
