Solution for valve clearance needed
Having attempted the Bruce Anderson 2.2 to 2.5 conversion and started final assembly I discovered I have Zero valve clearance :mad:
The only 2 alternatives I have come up with so far is adding 3x .5 mm base gaskets, which will unfortunately lower the C/R or start again with pocketed pistons. http://forums.pelicanparts.com/uploa...1663969496.jpg |
Those pistons were designed to work with the anemic CIS cams in the 2,7 motors.
I'm guessing you have either carb, MFI or other hot cams? If that is the case, your best bet is to get pistons designed for use with performance cams. http://forums.pelicanparts.com/uploa...1663975536.jpg |
I have a nice set of used Mahle 2.7RS pistons with new Goetze rings you can buy for $ 1,000. |
I'm using the original 1970 T cams but didn't realize they were incompatible .
I may well be interested in the Mahle pistons and rings Henry , If you could send some pictures and an shipping estimate to Ontario Canada I would appreciate it. Richard |
http://forums.pelicanparts.com/uploa...1664040934.jpg http://forums.pelicanparts.com/uploa...1664040934.jpg Shipping depends on method. I would guess $ 85 USPS. |
Thanks Henry , what would be a good time to call you ?
I will give you a call Monday morning.
Closed on Mondays. |
| All times are GMT -8. The time now is 12:57 PM. |
