-   -   Rasant closing it's doors (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1126969-rasant-closing-its-doors.html)
OSC911 09-24-2022 01:37 PM
I just got notification that Rasant is shutting up shop. I went to their website and nothing. I just did a EFI conversion using their kit - lovely gear and install went smoothly but have some issues with the crank signal so no smooth running as yet. I have been emailing them for weeks and no response. I eventually got and email with one line saying I might have a faulty crank Hall sensor and a link to another supplier to purchase one.
It is a bit of a shame as i think they has a nice products which provided a great upgrade to EFI. I was originally going to go with Al for the kit but I wanted Motec with COP and it was just easier to get the whole kit from Rasant. In hindsight, I should have gone with Al as, from what I can tell, his assistance with trouble shooting any issues with an install is second to none.
stanglife 09-24-2022 03:15 PM
Who is Al?
OSC911 09-24-2022 03:35 PM
X Faktory
Peter M 09-24-2022 03:49 PM
Bizarre
Andrew posted on Facebook 5 hours ago that the business was closing with no explaination.
Hope he is OK.
OSC911 09-24-2022 04:22 PM
Originally Posted by Peter M (Post 11806173)
Bizarre
Hope he is OK.
The email i received regarding my crank sensor wasn't from Andrew which I though strange at the time as Andrew has always returned emails himself. Yeah, i hope everything is OK.
Jabate 09-24-2022 05:40 PM
What is the model no of the crank hall sensor that Andrew used on your harness and who is the supplier that Andrew referred you to?
OSC911 09-24-2022 07:47 PM
Milspec Wiring which is Motec US. I tried Motec Australia and they don't have this sensor as it is US only - HS230
https://www.milspecwiring.com/Differential-Hall-HS230_p_422.html
Jabate 09-24-2022 08:41 PM
Do you also know the make and model of the Cam Position Sensor Andrew used in his harness?
mikedsilva 09-24-2022 10:17 PM
The last one I installed had a poor signal too. The reason in my case, was that the cam/crank sensor housing didn't put the sensor right in the middle of the crank trigger wheel. It was offset a little to one side. I had to elongate the hole slightly in the sensor mount so that it could be rotated in the distributor mounting hole. After doing this, we had a perfect and strong crank signal and it's run great ever since.
Also, don't forget to make sure you have a sensor gap of approx 1mm. (no more)
Worth checking just in case.
OSC911 09-25-2022 12:14 AM
Originally Posted by Jabate (Post 11806344)
I've actually emailed him as I want to order a spare. As soon as i know i'll post it up here
OSC911 09-25-2022 12:22 AM
Hey Mike, thanks for the heads up. I'll absolutely check this and let you know how I get on. I'm away with work at the moment but will check as soon as I get home. That makes a lot of sense now that you mention it.
The sensor adapter has a threaded 3/8" hole that the crank sensor threads into - is this the hole you elongated or the adapter mounting hole part where the nut goes onto the stud and holds the adapter in place? Appreciate your help as this is giving me a lot grief.
Henry Schmidt 09-25-2022 04:34 AM
I like Andrew so if anyone has a way to contact him, let me know.
I would like to make sure he's good. Small communities breed interesting connections and he's one we would hate too lose.
Cloggie 09-25-2022 08:47 AM
Ii too am very interested, since I have one of his complete systems just being installed into my restomod...
I was hoping once done to drive down to California and have him do the final tune plus shake his hand for a job very well done.
So, please keep us all in the loop in case he reopens or whatever....he is a treasure from my experience so far...
D.
Jabate 09-25-2022 09:46 AM
I found the cam position sensor on the MOTEC site under “cam sensors”
The unit on my harness is:CDC5900
Jabate 09-25-2022 09:54 AM
The mating connectors for the cam position sensor are:
DTM 4S - for harness
DTM-4P. For sensor connection
OSC911 09-25-2022 12:45 PM
Could you post a link - i can't seem to find it on the Motec/Milspec Wiring site.
Cheers
Todd
Peter M 09-25-2022 03:08 PM
Guys,
You are not limited to Motec or Rasant supplied sensors. Your Motec and any other aftermarket ECU for that matter will run successfully using any suitable quality sensors of which there are many to choose from. For example I use a Clewett crank sensor and cam position sensor for my Motec M130.
https://www.clewett.com/index.php?main_page=index&cPath=5_29
Todd, Haltech make a lot of stuff locally that may interest you for your Motec setup.
https://www.haltech.com/product-category/inputs-and-can-expansion-products/pickups-triggers/
It's unlikely your Hall effect sensor is faulty unless it has been powered up incorrectly, I suspect it's just a minor wiring issue. If you live around Newcastle I can personally recommend a tuner who would sort your problem out quick smart.
Consequently there is no point panicking about Rasant's closure as there are plenty of other sources of parts, good advice and alternative aftermarket support for the EFI conversions Andrew has sold you.
I agree it's a pity Rasant has closed as Andrew has certainly been an inspiration to me.
Jabate 09-25-2022 03:32 PM
Todd
You can find the MOTEC sensor if you select: MOTEC.com
You can next select the ECU: e.g., M84 ; M130
Next select:ACCESSORIES , UNDER THE LEFT “PRODUCTS” column
Next: select “Sensors”
You will then see a list of sensors.
Note:It is essential that you have the correct air-gap set for your sensor
OSC911 09-25-2022 04:05 PM
Originally Posted by Peter M (Post 11806799)
Guys,
Thanks Peter M, appreciate the links. Rasant did the harness so hopefully it isn’t that. If it is the wiring I would appreciate the contact in Newcastle if he is the man to go to. It is a fair way to travel but happy to do a road trip with a car trailer to get it right and a tune while I’m there.
Todd
Peter M 09-25-2022 08:02 PM
I've PM'ed the details to you Todd.
Cheers
