-   -   Oil inlet check valve -- beware.... (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1127094-oil-inlet-check-valve-beware.html)
bmsr 10-26-2022 12:51 PM
Just a note on the check valves - the instruction sheet from Rothsport clearly states not to use them on a new engine start up. As previously stated use a plain s hose on new startups then switch to the check valve if desired.
