-   -   Undersize Main Bearing Source (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1127197-undersize-main-bearing-source.html)
Ovis 09-28-2022 11:39 AM
I had to have my 66mm Crank ground .25 under. I need to obtain main bearings. I have heard that the Glyco bearings have had some issues in the past and should be avoided.
I have been advised to use clevite coated bearings. Does anybody have any suggestions on where to source and obtain these bearing, or any other relevant advice to purchasing undersize main bearings for my motor? Direct links are always appreciated.
Thank you in advance!
SBell 09-28-2022 12:42 PM
I got mine from Henry at Supertec last year.
Sent from my SM-G991U using Tapatalk
john walker's workshop 09-29-2022 12:31 PM
Try EBS Racing.
Zuffenwerker 09-29-2022 05:49 PM
Porsche Dealer
Dpmulvan 10-01-2022 07:46 AM
Clevite coated bearings are only available as rod bearings for our cars.
Ovis 10-01-2022 10:37 AM
Thank you all for the information.
