-   -   P234 rear main seal tool available? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1128134-p234-rear-main-seal-tool-available.html)
rockreid 10-14-2022 03:03 PM
Getting ready for my JE piston set 73 2.4L rebuild 911T and in need of the p234 or equivalent rear main seal install tool. Is there one floating around this forum to buy? I only need one use (hopefully) so it isn’t really economical to buy a new unit.
rudedude 10-14-2022 03:48 PM
Where are you?
john walker's workshop 10-14-2022 05:51 PM
Small plastic hammer. Cheap.
Zuffenwerker 10-14-2022 06:23 PM
I’ve got that tool, the best part about it is that it’s fool proof. Tapping in is just as good as long as the seal stays square - if they are at all crooked it’s a leaker
Jeff Alton 10-14-2022 08:46 PM
We have the tool as well, I rarely use it, but our techs use it all the time... It is fool proof and creates consistent repeatable results, which is important in a shop environment.
Cheers
boyt911sc 10-15-2022 10:53 AM
Home made P-234 tools.........
Go to your local hardware stores and look at the plumbing section for these pvc parts or find a scrap steel plate.
http://forums.pelicanparts.com/uploa...1665855660.jpg
Tony
Jeff Alton 10-16-2022 06:34 PM
The one advantage of the tool is that it sets correct depth.....
cheers
Cloggie 10-17-2022 02:28 AM
cheers
I thought correct depth was the seal outer flange being in firm contact with the case....is there a spec that is different?
Or is it just mitigating the risk of hammering too hard and squishing the seal in some way?
D.
Zuffenwerker 10-17-2022 07:44 PM
D.
The OG original Porsche tool for the 9 bolt crank installs the seal flush. The SIR tools p234 goes in past flush. Both work.
The original post mentions a 73 crank so he actually needs p215 which also just drives the deal flush.
Dpmulvan 10-20-2022 06:03 AM
A lathe pays for itself really fast when you need NLA or $$$$ tools.
strictly 10-22-2022 05:45 AM
Tony
Tony, whats the difference between the green version and the metal plate? Which one do you use for the 9 hole flywheel? The white is for tapping?
On installation, I would generally fit a seal (using a "screw" tool like the above) until the seal bottom end sits against something (like the case). If it happens to be "flush at the other end" because of the seal dimensions, then "so be it".
Is this foolish for a 9 hole flywheel crank seal (or any other), and it would be better for it be "flush" regardless of whether the bottom edge is up against the case?
boyt911sc 10-22-2022 09:00 PM
Strictly,
The depth of the circular cavity is several mm more than the thickness of the rear main seal. So if you install the oil seal flush to the edge, there is still several mm clearance before the backside comes in contact with the crankcase. I have some measurement done years ago and if my memory serves me right, the space is about 3~4 mm clearance.
Basically, the green PVC and the steel plate work the same way as pressure plates. The three (3) bolts are tighten gradually to push the oil seal smoothly and flush to the case. I use the same bolts for the PVC and the steel plate. The bolts shown in the picture for the steel plate were my proto-type fasteners I just picked from the tool box. The regular hexagonal head bolts are what you need. Nothing fancy.
Tony
dtxscott 10-27-2022 07:33 AM
Super Big Gulp cup from 7-11 worked for me.
Here's the writeup
http://forums.pelicanparts.com/porsche-911-technical-forum/1104955-flywheel-side-crank-seal-installation.html
