-   -   ARP bolts touching inside of case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/1129043-arp-bolts-touching-inside-case.html)
Anders. 10-29-2022 01:37 PM
Hey. I have a problem where my newly installed ARP rod bolts is slightly touching the inside off the engine case. Is this a known problem? In the pictures you can see where it has slightly shaven off magnesium shavings. Is there something I can/ should do about this?
-Andershttps://uploads.tapatalk-cdn.com/202...0e76a95e55.jpg
https://uploads.tapatalk-cdn.com/202...5b923167be.jpg
john walker's workshop 10-29-2022 02:27 PM
What engine and what part number for the bolts?
john walker's workshop 10-29-2022 04:05 PM
http://forums.pelicanparts.com/911-engine-rebuilding-forum/1117045-arp-rod-bolt-part-numbers.html
Zuffenwerker 10-29-2022 07:07 PM
You should fix this, luckily you can remove the rods without splitting your case…maybe you change out the bolts. What case crank and rods do you have?
winders 10-29-2022 07:10 PM
But can he remove all the metal flakes without splitting the case?
Trackrash 10-29-2022 10:50 PM
Are the pistons installed? And the bolts are hitting when rotating the entire crank, rods and piston assembly? I ask because the rods can hit without the pistons guiding them in their correct alignment.
Dpmulvan 10-30-2022 06:49 AM
Your gonna have to split the case and get rid of all those shavings and do a proper inspection.
