2023 State of CIS
I'm curious what others think about the current and future state of CIS induction.
I've been driving my '78 SC with no troubles for almost 30 years (eek) until this summer. I was more than a little shocked to find out the Aux Air Valve that failed was a $1300 part ($1100 on Pelican). Browsing the catalog I see a lot of darned expensive and NLA parts, making me wonder if I should count on CIS going forward or start thinking about alternatives. My particular application is a track car so I don't have have smog/inspection concerns. Thanks for any input. -Vic |
I was asking the same question 12 years ago when I rebuilt my 2.7. I am still running CIS today. There are reconditioned used parts available. You can get new injectors and airboxes. If I had to rebuild my engine today or was looking at a major CIS rebuild, I think I would be chasing an EFI refit on a common plenum intake (or ITB's). There are many more affordable options today versus 12 years ago.
I am amazed at how well they run and hold up with little to no adjustment. My 40 year old CIS runs perfectly (knock wood) and efficiently with good gas mileage and when I put my foot in it.
I could go with carbs for less mileage and a miniscule take off boost and then have to play the balancing/adjusting game...no. EFI, yes, if everything went south seriously but I'd be more inclined to repair whatever needed doing as it works so well as is. |
Good reliable system, as long as someone has not tried to "fix" it in the past with a work around...
Cheers |
I imagine there’s still a bunch of cis systems out there sitting on shelves as spares. Think I have 3 or 4 laying around.
Spare AAV.........
Vic, How did you test the AAV? I got several AAV that were tested and confirmed good in case you still need one. http://forums.pelicanparts.com/uploa...1667862907.jpg http://forums.pelicanparts.com/uploa...1667862907.jpg Tony |
-Vic |
-Vic |
Thanks all for the input to date. I'm leaning toward keeping the CIS for now. That makes several of my rebuild decisions simpler. If it does go south, the full EFI seems like a good plan. This thread was interesting: rhd-itb-megasquirt-install
-Vic |
I've got over 50k miles on my rebuilt '78 targa 3.2ss with stock CIS. It's easy to tune the mixture with a wideband O2 and makes plenty of power for my taste. It's been dead reliable, 20mpg, and the only reason I need my laptop on road trips is to answer emails ;)
Forget about Megascrap, get a good commercial alternative, they aren't expensive anymore. They have support and tuners willing to work on them. |
When your efi takes a dump in the boonies, you better know how to deal with it, because most shops won't know jack about it.
At least over here every kid in the boonies who has a modified car can hook up a laptop and fiddle with their boost maps... These days EFIs has bluetooth and with an app on your phone you can easily connect and get error messages and see faulty signal. I've ran an aftermarket EFI on my first car for 15 years (no fancy bluetooth) and it has let me down once and that was due to corrosion on the old ceramic fuses panel in the engine bay. As long as there an crank shaft signal its incredibly resilient. |
I did my first Programable EFI set up over 20 years ago. I used a 3.2 intake on a 3.0 SC. Used in my track and street car. I eventually sold the whole system to my friend. He is still running it today. It has not been touched since it was installed on his car 12 years ago. If the ECU died today there are tons of options that could replace it.
john |
Since I've owned, 81sc cis stock, 20000 miles, not a hiccup. Don't know what others are going through, but I am sure this has been an easier ride for me than any other conversion.
75 cis no problems (after air box leak found) many years ago.
Well, if your CSI works good, maybe you will be fine, until you aren't.
But if you want to extract all the horsetorque in the engine, you do that with EFI. Another thing is the ease of adjustment when you get more and more ethanol in the fuel. So instead of whining about the ethanol fuel you realize that the more ethanol there is the better the car goes! |
You need Fuel rails. (can be made if there is none available, a set of 3.2 might be modified) Adapters for injectors (I made some for my 924) A tps adapter (this can be tricky) Crank signal, fit 36-1 or 60-2 trigger wheel. (Patricmotorsport have a flywheel with 60-2 trigger) As ECU I have used 3 different systems, the latest is a Maxxecu, a local to me Swedish company and that is really easy to use, very capable and pretty affordable. Available worldwide of cause. |
MAXXECU is a very good ECU. Tons of capability/programability...
We have done plenty of ECUMASTER BLACK ECU as well. Very good/capable system for not a ton of money. We run them in a couple of race cars, our E85 full modified Mini Cooper. Very good. MegaXXXX Why bother with a toy system in this day and age... Cheers |
Thanks again for all the input. I'm sticking with CIS for now. I plan to spend the winter getting more familiar with the system so I have a better chance of keeping it running in the coming years.
-Vic |
The basic system on a 1978 (no oxygen sensor or Lambda control) is easier to diagnose than 1980-83 cars, but you will need appropriate tools: a smoke machine to locate air leaks, a gauge set to measure system and control pressures, a simple vacuum hand pump to check the WUR and vacuum limiter and, most importantly, a good understanding of how the system functions. One excellent source of information is the late, great Jim Sims' jimsbasementworkshop. There are also several Pelicans who understand the system quite well and post regularly. Good luck and enjoy your classic. |
| All times are GMT -8. The time now is 03:56 PM. |
