Fitting size...oil pressure line from case
Did Porsche change the fitting size when they went from the early rubber line to the steel line under the trannie? TIA
Old 11-25-2022, 11:10 AM
Yes , the oil line is larger for '72 MY and newer cars , and the fitting is larger .
Old 11-27-2022, 07:18 PM
BoxsterGT's Avatar
Porsche Crest
Early 911 Oil Lines from model years 66 to 70 were 26mm.
The 70 - 71 models had a mix of 26 & 30mm.
72 on had just 30mm. The threads in the case for all models are M22 x 1.5.
I have just about any 26 or 30mm steel fitting you may need, along with the correct 26 & 30mm Oil Hose.
I do not have the Aluminum Argus fittings used on the very early models.
len.cummings @ verizon.net
Old 11-28-2022, 05:17 PM
